Custom Oil Return Line?
SteveX82 Offline
With the absurd prices of t3 oil return lines (even used ones), I've been tempted to custom fabricate one myself. I've considered just welding some sort of fitting onto the bottom of the center section and using a steal-braided line to connect back to the block (i've heard that using a rubber tube is not a good idea). Do you guys think this would be a safe alternative?
Also, I've given up on the idea of retaining my intercooler in it's stock location with the new t3. Not only would I have to machine off the flange and figure out a way to securely mount the intercooler hose, but i'd have to find a way to connect the oil breather cap line and the wastegate flange as well. So instead I've decided to weld some sort of elbow onto the compressor outlet and simply use a front-mount IC instead. But then I'd be eliminating the two vaccuum ports on the intercooler....Would I even have to worry about that? And as always, thanks for any help.
maroon 1987 TC 5spd, 128k miles
k&n cone in fenderwell, gillis valve set at 17lbs, kirban adjustable fpr set at 40psi, walbro 255 hi-pressure pump, bosch hi-pressure bypass valve, ported e6
Best 1/4 mile: 14.778 (with 2.198 60' time)
Best trap speed: 94.01mph
On the oil line, braded should work. just make sure that it's ID is as large as the ID of the stock return line. Oil coming out of th eturbo at high speed is more like foam than oil and the additional line diameter is needed to get it out of the turbo and back to the pan.
On the vac lines from the i/c. Disconnect them, plug them and see what happens. Be sure to test your speed control.
Dan E Offline
Turbonetics makes a flange specifically for a T3 oil return line (the side that attaches to the turbo).
Dan Eaves
Dan Eaves
