custom built intake
Twofast4uturbo Offline
Well the other night i got borded and finshed this intake up. I was going to use one my car before i got the esslinger svo alum. head and ended up not using it or testing it out i got the idea from Ricks xr4ti that ran over 200 mph at bonneville but made some changes not to copy anybodys ideas what do you guys thing any one interested in it ?
another pic.
ok that is that last pic you would have to move the alt. and put a front mout he intercooler but i think it should work really good .
BJL Offline
Moderator
i have a wuestion about it. with ti havign alarger area inside then a stock intake whast teh advantage. i dotn understand area verus mass etc, woudl that be a great gain havign that much space inside? liek a resever air tank???
im jst not getting it.
i woudl think a 3 inch pipe intake split evenly off to 4 2in pipes to each port woudl be an advantage? right?
can soemoen explain this!
i have the erge to learn
Brian J Larkin
1988 Non-Turbo Turbo Coupe
new paint job as of 12/8
med gray met. raven/gray interior, fully loaded minus leather and sunroof!
converted to N/A 2.3l by previuos owner, but its a nice driver with working A/C!
sequentail turn signals, 3g alt,afpr, k&n, 2 1/2in cold air intake.
custom 2in dual exhuast with SN95 SS tips. Tripcomputer, a/f and vac guages. color coded wheels
1988 Turbo Coupe 5spd
gillis boost valve, k&n cone,AFPR, 255lph, HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
(needs a front frame pull) DOH!!!!!
Brian Larkin
88TC 330,000 miles
Slightly Modified
servingGod Offline
BJL I think you need a new keyboard! LOL
88 TC 5-speed maroon, all options, plus t3/t4 hybrid, 255 pump, RR, Centerforce DF with weight fingers, MSD tfi coil.
88 TC 5-speed Black, all options.
88 Thunderbird LX 5.0 All options except Leather.
87TC Parts car five speed all options.
All right i know that the intake on turbo cars need long runner big volume to help spool larger turbos like a resurve when racing or full throtle.
I looked at hondas and other intake before i made this one i made it a little bigger than Rick Byrnes salt flat car and made a super coupe t body bolt up and throtle bracket i was going to port the lower in the pic. but never finshed it because i got my hands on a esslinger head and then my intake woud not work so its bee sitting untill i took some pics and just wanted to see if any body would like it i guess i might put it up for sale on ebay .
BJL Offline
Moderator
its nopt the keyboard, my wireless keyboard made it look worse, its just me now, ha ha ha.
ok so it helps spool, that what i didnt understand. i guess it woudl help with coolign also./ thansk for clarifiying
Brian Larkin
88TC 330,000 miles
Slightly Modified
