Scott Mabe
Nov 2013
Virginia
The problem I'm having is if I try to use cruise control my TC tries to set a world land speed record! Soon you hit "SET" it starts accelerating until you turn cruise off. Any ideas?
1987 Turbo Coupe
1990 F-250HD 460ci
TurboBoost88
Nov 2011
Owensboro KY
sounds like a sticking switch.
Or a stuck / bad vac apply valve in the CC servo. Unlikely to be the CC control unit (i.e., CC "amplifier"). They rarely fail.
Scott Mabe
Nov 2013
Virginia
Like my signature says, the tc is new to me. The first couple times I tried cruise it worked fine. Then the other day before I had to work on the instrument cluster it started acting up. The car was supposed to have been parked for 6 or 7 years before I got it. So with that info, does that change anything?
1987 Turbo Coupe
1990 F-250HD 460ci
The CC amplifier is up by the firewall on the driver side. Black plastic box about the size of a pack of cigs. About 6 or so wires going to it (I forget how many wires exactly). Any chance you kicked it, damaged the wiring to it when you had the cluster out?
Scott Mabe
Nov 2013
Virginia
I don't believe so, since the problem showed up before I pulled the cluster.
1987 Turbo Coupe
1990 F-250HD 460ci
Scott Mabe
Nov 2013
Virginia
Figured I'd update, as of right now the cruise is working the way it should. Didn't do anything, it just started working.
1987 Turbo Coupe
1990 F-250HD 460ci
