Hey guys, I just picked up a new transmission cross member and mount, the mount is a polyurethane(energy suspension part# ENE 41104 R) and it works great but my question is the old cross memeber has the 2 side bushings(left & right) and on the driver side it has another one made out of rubber bolted on the cross member with metal running through it. DOES ANYBODY KNOW WHAT THE HELL THIS DOES I have another one just like it at the end of my transmission, the new crossmember does not have the holes to bolt on this mount, If anybody knows what it does ,should I tapp the holes and install it or should I toss it? I talked with Pete and his TC doesn't even have this rubber mount has anybody seen this mount on there TC before?
1987 tc Boost Valve,Kn Filter.Motorsport roller cam high rev springs,new prc shocks and springs.3'down pipe high flow cat walker turbo II mufflers 2 1/2 inch dual exhaust.
1987 tc Boost Valve,Kn Filter.Motorsport roller cam high rev springs,new prc shocks and springs.3'down pipe high flow cat walker turbo II mufflers 2 1/2 inch dual exhaust, center force II clutch
