crazy idle
Noname
Guest
I NEED HELP MY 86 T.C. RUNS FINE EXCEPT WHEN IT WARMS UP,AND I COME TO A STOP IT STARTS TO IDLE VERY LOW,SOMETIMES IT STALLS OUT AND AFTHER IT STALLS START IT RIGHT BACK UP AND ITS FINE LIKE NOTHING HAPPENED.IT DONT DO IT WHEN ITS COLD,ONLY AFTHER A 20 MIN DRIVE,AND IF I TRY TO GIVE IT A HIGH IDLE IT WONT DO IT,ONLY AFTHER ACTUALLY DRIVING THE CAR.HELP
See the thread "Sputter....Die". Sound like you have the same problem
and jack rails.
Keith Nubel Offline
You could have any number of problems. Sticking EGR, vacuum leak(s), Idle control and TPS. Make sure all are clean and set correctly. Intake manifold gasket(s) can also cause problems.
85 TC 5 speed, K&N filter charger, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount intercooler, underdrive pulley, ported upper and lower intakes, 245/45/17 wheels & Tires
1985 TC
