Hi guys,
I'm new to the sight, great information here.. thank you.
I'm rebuilding a 2.3L Lima out of a 88 TC. The problem I'm having, I had to remove the crankshaft sprocket to get at the front seal. That was a chore in itself, I tried heating it, I tried two versions of a homemade puller. Finally had to drill and tap the sprocket and try to use an "H" puller to pull it off the crankshaft. That ended up snapping the sprocket in half. So I replaced the seal, ordered a new sprocket, tried to slide it on only to find it was too small for the crankshaft by just a touch. I tried heating the sprocket, not red hot but pretty hot and still could not slide it over the crankshaft. I have two more sprockets coming from an 88 2.3L out of TCs. I pray one of those will slide on. I saw where others had only to slide them on no problem. Have you heard of this before, a crank sprocket not fitting the Crankshaft? It's like the Crankshaft is the wrong size. When putting new rod bearings on the crank, everything went together well. I plasti gauged everything, I was on the tight side of standard but everything fit well......... Any suggestions?
Thanks,
Harl
Thanks,
Harl
