TCKNIGHT76
Mar 2008
columbus, oHIo
Does anyone know what other coolling fans will work on the 88tc? The one that is on my tc is from a mustang or a ranger I don't know which. I know the fan doesn't work I have wired is strat and will not work. So which fan is the best to replace it? Thanx
88 turbo coupe
Bov
Eatin bc
K&N filter cone style
Pony wheels
60mm tb have it ready to go on
98 explorer
5.0
Awd
KEEP IT OUT THE RED!!!!!!!
You could probably find a used unit. There is also an article on diagnosing the stock fan set up;
http://www.turbotbird.com/techinfo/Cooli...ingFan.htm
Replacement motors can be had, used and new
Iv'e put a Spal after market on mine. I got some issues that I haven''t diagnosed yet so I don't know if it's the fan or some of the wiring yet. There are several brands of after market fans available. Whatever way you go you need to consider a fan shroud to get the most cooling out of the fan
TCKNIGHT76
Mar 2008
columbus, oHIo
Well I went to the junkyard today and couldn't fine any tbirds from 83 to 88. I ended up gettin a fan from a 96 ford tbird. It covers about 90% with the fan and the rest is the shround. I haven't got it on yet so when I do I will let you know how it works. Pete I am also still haveing the trouble with it spittin and spuderin.
88 turbo coupe
Bov
Eatin bc
Pony wheels
98 explorer
5.0
Awd
Quote: Pete I am also still haveing the trouble with it spittin and spuderin
Me to but my car is running fine
I sent you a reply by email a couple days ago. Basically I need more info????? What have you done so far?
TCKNIGHT76
Mar 2008
columbus, oHIo
Pete I sent you a reply to ur email. I don't know why it wouldn't have came to you yet? Send me another email and I will send what I have done.
As for the fan you all I got it wireed in to the factory wirein and it didn't work. I know the new fan works checked that with a dewalt battery. So I got on the site here and was goin to try and fit it like the site says but when I dove in to the wirein I got scared... Lmao I juz ran a wire from the fan to the dash and a switch there and used the factory wires for the key switch on the radio and blow a fuse rite off the bat...lol I put a bigger fuse in to replace the 20 amp fuse with a 30 amp for the more amps the fan draws.
88 turbo coupe
Bov
Eatin bc
Pony wheels
98 explorer
5.0
Awd
You can get aftermarket ones that come with (may be optional)r=their own temperature sensing units. Whatever you do, consider using relays and new wiring as opposed to relying on any part of the factory wiring
