Anyone have a wiring diagram of the Cooling fans on an 87 TC? I have a single Derale 17" 2 speed fan in place of the dual fans. I've noticed that one of the wires gets extremely hot, like melting the weatherproofing off of the connector, can't touch the wire, hot. I'd like to double check my connections and wire in relays if necessary.
When running, the fan is pulling about 14amps on low speed, haven't tested the high speed setting yet. 14amps is what Derale states is the low speed amp draw, high side should be around 25 amps.
Are the fans switched on the positive side, or are they switched on the ground side?
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
