Coolant system?
3bird Offline
After replacing a faulty thermostat and flushing the system, the car still won't warm up to normal operating temp when I'm out on the highway. Can these engines get a bubble in the system if they're not flushed properly?
tps87turbo Offline
Most definately. I usually run the system with the radiator cap off for about 15-20 minutes. As the system draws the coolant down, I fill the radiator really slow to prevent the air pocket. My car burps just like I do when I drink too much beer too fast. [Image: tongue.gif]
Your problem may also be a clogged heater core. Are you sure water flows thru the core and not trickle out slowly? Your water pump may aslo be the culprit -it may be bad as well by not pumping enough water thru the system. just need to rule out all possabilities
Tony Sceia
Red 88 TC loaded with every option, Walbro 255, 3" SS Downpipe with Magnaflow SS 2.5 Cat Back Mustang Dual system Installed by BJL, 3-core Radiator, Star Stage 2 Clutch, Rebuilt T-5 Tranny, 140 MPH Speedo
Now I need to finish converting to Raven/Gray Leather interior & just do some Body work & she'll be like new.
Tony Sceia -
HIS Red 88 TC
