Coolant Return Line Fitting In Block Questions
fatty Offline
Hello fellow message board members. I am new to this forum. I have done the search already and performed the same search all over the interwebs. I have not had any luck finding an answer to the question so now I post it to you all in hopes I can have an answer.
I bought a 86 2.3 turbo engine out of a wrecked thunderbird to put in my motorless 86 Thunderbird. Somewhere along the lines someone removed the return coolant line from the block and turbo. I have seen pics of it and its a little nipple looking fitting that threads in the block. What size are those threads?????
Also thanks for showing me a few great ways on getting around the trashed coolant supply line. That copper job was beautiful.
Welcome to the board.
It looks like 1/2" x 20 pipe thread
fatty Offline
Thank you so much!!!!!!!!!! This board has alot of great information.
Robert Camp Offline
Pete, perhaps you're describing the oil return fitting??? In the blocks I have I find a 1/4-18 NPT nipple fitting for the water feed line on the lower right block.
BTW, for the turbo the feed line is from the lower block, the return line is to the line off the thermostat housing.
Robert Camp
Robert. Are we talking the same thing here? I may not have stated the size correctly. It is a tapered thread and the largest diameter is just under to 0.5" dia. I didn't have the factory fitting but did use something else that seemed to fit the hole perfectly. My thread gauge said 20 but the light wasn't real great
http://natomessageboard.com/uploads/0000...eturn4.JPG
OK I took the fitting I was using to a plumbing store and they said it's a 1/4 and the thread pitch is 20, had someone else verify that. I don't know what size the barb is as I don't have one handy
Robert Camp Offline
Yep, pipe thread sizing doesn't match up with machine bolts. The 1/4 inch is supposed to represent the pipe ID. So a 1/4" fitting will be larger. Sorry I got the thread pitch wrong, I stupidly used the first pitch that came to mind instead of verifying. I believe that's considered a 1/4" barb. The adaptor is a 1/4-20 NPT to 1/4 barb fitting.
Robert Camp
fatty Offline
That is the fitting I bought the 1/2 and it was too big then swapped it for 1/4 one now i need to go back to get the right barb size they gave me a 3/8 one its HUGE!!!!!!!!!!
Thanks again everyone!!!!!!!!!
Fatty, Sorry about the mis-information.
