coolant recovery tank
Andrew Offline
My recovery tank has a crack right where the mounting bracket is so that under normal conditions I loose no coolant, but when I get after it, the coolant sloshes out and steam comes from the hood.
Not a good way to show up at a restaurant. I have tried to find a factory bottle, but I cant find a listing for a turbo specific one. Is it the same on the v8?
Also what other options have people successfully used to mount an aftermarket/ universal recovery bottle?
Thanks for the help
Andrew
88 turbo coupe. Daily driver
Not the same as the V8..... the V8 one is located on the outsode of the core support. I bought a new one a few years ago from some mustand restoration web site, but I dont remember the site or how many they had Sad
KY Bird Offline
I'm moving this week, but I think that I packed one up from the parts car. It might take me a week or two, but I'll let you know if I find it when I get unpacked.
Bill
300K and still ticking
'88 TC Silver (Titanium Frost) Mach One, 5-speed, K&N, 14* timing, dual 2.5" exhaust, tripminder, the rest is stock
'87 TC Parts Car RIP
'03 Escape, Killed in Action
'08 Taurus X Baby Mover
'89 Buick Reatta
Andrew Offline
that would be amazing. I am trying to keep this car original but i cant exactly go all out on a college budget lol
Andrew
OU812MACH1 Offline
if u cant come up with a good used one....J.B. weld makes a white putty # 8277 that u can use with gas or glycol antifreeze...works on metal ,plastic, steel , copper ect ect...u can try that...some people call it'' pig putty ''...
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
georgechard Offline
If you dont find one I have a good used one make me an offer. Im in ga also.
georgechard Offline
You could drive slow and it wouldnt splash around. LOL
Andrew Offline
Thats the thing i normally do drive nice and slow, but my roomates girlfriend was in the car and she makes funny noises when we hot rod.....lol
Andrew
BJL Offline
Moderator
im switching to a V8 style .... there are more of them with out cracks... il let you know how it works out
Brian Larkin
88TC 330,000 miles
Slightly Modified
The V8 one should work fine, and has more capacity that the 2.3T one..... something like 3.5 quarts. Be sure to grab the upper mounting bracket along with the tank.
