zip
Dec 2006
Modesto, CA
Hello I have a 86 turbo coupe and i keep losing coolant through the drain on the firewall under the heater core. I start the car I can see a substancial amount of coolant draining from the drain. When the car is shut off the coolant still flows out until im left with a low level of fluid in my radiator. Any help would be much appreciated.
Matt
Matt
CougarXR7
Jun 2006
Marietta, OH
A drain on the firewall?
It sounds as if the lower hose is disconnected from the heater core.
1986 Mercury Cougar XR-7
5-Speed - Leather - Dual Manual Seats - Vent Windows - Smokin' T3
zip
Dec 2006
Modesto, CA
Ya it is on the firewall behind the downpipe from the turbo. I think it is a drain, ive looked through a haynes manual and thats what i had come up with
Matt
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
thats the drain that tells you your heater core went bad. theres a collector under it to drain the coolant OUT of the car. either bypass the heater core, or replace it. DO NO PLUG THE HOLE, you will backflush coolant into the interior, ruining your carpet.
-J0N
P.S.-if you ever see(hear) hissing coming out of this hole, or maybe see bits of clear oil, that indicates your A/C coil has gone bad...also not good.
zip
Dec 2006
Modesto, CA
Thank you for all the help, I was thinking it was the heater core but now i know. I guess i know what im doing on saturday morning. Ill keep a look out for teh hissing to make sure its not the A/C coil. Once again thanks for the help CougarXR7 and jmthunderbirdturbo i appriecate it
Matt
Matt
CougarXR7
Jun 2006
Marietta, OH
Wow. I just learned something new. I had no idea there was a drain for the heater box.
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
well, there usually isnt... see its usually gone/damaged before the heater core goes out. sometimes you get lucky and dont have to wet/dry vac the interior, and sometimes you do...
-J0N
Martin
Aug 2001
Agassiz, BC, Canada
All AC'd cars have a drain tube, to get rid of the condensate from the AC coils when they frist up and then thaw out. The binus is if the heater core is going, the coolant will also e trapped in the AC drain pan and if th etube is not plugged, allows the coolant to drai nout as well.
Martin
Boost High, Fly Low
