nunnaro
Jul 2020
Long Island NY
This is perhaps a 2 part question. Has anyone converted a 87/88 T/C from automatic to a 5 speed? I have a donor car so parts shouldn't be a problem. I'm also wondering about the difference in horsepower between the 2 transmissions. Is it a computer change or is it more complex?
Kuch
Sep 2016
Manlius, NY USA
Great idea to change over to the 5 speed as the auto in these cars will not take ANY abuse. Since you have the donor car, it should be straight forward. Are they both the same years? You should also swap over the computers from auto to manual. The horsepower differences between the 5 speed cars and the auto was done by the factory to keep the auto trans from falling to pieces as it is very weak. Lots of people have converted theirs over on here, make a checklist, do one section at a time, check it off when you do it. Maybe take pictures of items that you may forget about to help with assembly. The toughest part would probably be the hydraulic clutch reservoir as there is not a lot of room around the brake master cylinder on the 87/88's.
nunnaro
Jul 2020
Long Island NY
(12-22-2020, 03:25 PM)Kuch Wrote: Great idea to change over to the 5 speed as the auto in these cars will not take ANY abuse. Since you have the donor car, it should be straight forward. Are they both the same years? You should also swap over the computers from auto to manual. The horsepower differences between the 5 speed cars and the auto was done by the factory to keep the auto trans from falling to pieces as it is very weak. Lots of people have converted theirs over on here, make a checklist, do one section at a time, check it off when you do it. Maybe take pictures of items that you may forget about to help with assembly. The toughest part would probably be the hydraulic clutch reservoir as there is not a lot of room around the brake master cylinder on the 87/88's.
The donor vehicle is an 87 the automatic is an 88. Did you or someone you know actually do one? I thought about the reservoir myself as it is cramped as you point out. The donor car is an original 26000 mile car but sat outside for too long and is starting to rust out in spots. Too much to tackle. I kind of figured the horsepower difference could be solved by the factory via the computer. Do you know of any other changes that would be required? Any help/advise would be appreciated. Thanks for the post. Happy Holidays and God Bless!
anasazi4st
Feb 2015
Phoenix, AZ
(12-25-2020, 08:34 PM)nunnaro Wrote: (12-22-2020, 03:25 PM)Kuch Wrote: Great idea to change over to the 5 speed as the auto in these cars will not take ANY abuse. Since you have the donor car, it should be straight forward. Are they both the same years? You should also swap over the computers from auto to manual. The horsepower differences between the 5 speed cars and the auto was done by the factory to keep the auto trans from falling to pieces as it is very weak. Lots of people have converted theirs over on here, make a checklist, do one section at a time, check it off when you do it. Maybe take pictures of items that you may forget about to help with assembly. The toughest part would probably be the hydraulic clutch reservoir as there is not a lot of room around the brake master cylinder on the 87/88's.
Did you read through this? Converting Automatic to 5 speed. While it doesn’t exactly tell you how, there is a list of parts you’ll need, most of which should be fairly obvious.
I’m not sure about swapping ECMs (computers) between cars with different years—someone else here can give an opinion on that. There were some minor changes, but I would think likely not enough to cause any serious issues.
nunnaro
Jul 2020
Long Island NY
(12-26-2020, 01:20 PM)anasazi4st Wrote: (12-25-2020, 08:34 PM)nunnaro Wrote: (12-22-2020, 03:25 PM)Kuch Wrote: Great idea to change over to the 5 speed as the auto in these cars will not take ANY abuse. Since you have the donor car, it should be straight forward. Are they both the same years? You should also swap over the computers from auto to manual. The horsepower differences between the 5 speed cars and the auto was done by the factory to keep the auto trans from falling to pieces as it is very weak. Lots of people have converted theirs over on here, make a checklist, do one section at a time, check it off when you do it. Maybe take pictures of items that you may forget about to help with assembly. The toughest part would probably be the hydraulic clutch reservoir as there is not a lot of room around the brake master cylinder on the 87/88's.
Thanks for your post. I had forgotten about the fac's area of the sight.
If you plan on keeping the POS stock boost control solenoid switch to an LA2 or LA3 PCM. If you plan on going to a manual boost controller (Gillis valve, etc) the original PCM (probably an LB2) will be fine.
nunnaro
Jul 2020
Long Island NY
Jeff thanks for the info. I have a question. How do I access the TURBOCOUPE FAQ section for additional questions?
Kuch
Sep 2016
Manlius, NY USA
If you scroll down on the "Home" page with all of the different topics, there is a FAQ section
teal95
Dec 2002
Grass Lake, MI
I've done several but always used a cable setup from a Mustang. Pretty straightforward. Computers don't really matter. I've always just looped the wastegate line to bypass the solenoid, which gives about 17 psi.
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
(05-07-2021, 12:54 AM)teal95 Wrote: I've done several but always used a cable setup from a Mustang. Pretty straightforward. Computers don't really matter. I've always just looped the wastegate line to bypass the solenoid, which gives about 17 psi.
So I'm curious about this. I did this the other day to my car and I'm only getting around 10# of boost which is what I got before since it's an automatic car. This is the factory gauge and I know they aren't the greatest but going off the gauge this made no change. I will say that it does seem to spool up faster and it feels like it made a difference but it wasn't huge.
Is it possible that the wastegate is opening without signal from the solenoid? Can it be pushed open if the spring/actuator are fatigued?
