Computer problem
Go Roush Offline
I have an 83 5speed computer, will I be able to use it with a 88 motor and same 5 speed wired in the 88 wiring harness but no luck on firing, have spark and fuel Thanks for the help, greatly appreciated
03 Ford F150 Supercrew
07 Suzuki Boulevard C50T
1983 Turbocoupe
There are a few different pinouts but I haven't done that swap. Check your email
Tbird-fanatic Offline
which vam and injectors are you using?
^^^ +1 to boht the above comments....
Be sure you moved the pins in the 60 pin connector to the correct locations for the 83 EEC. You MUST use the small VAM and 30 lb green top injectors with the 83 EEC.
Go Roush Offline
What's the proper procedure for moving the wires on the connector and I have the turbo and all from 83 but the injectors I didn't move
1983 Turbocoupe
Not B Anymore Offline
So you put an '88 motor and wiring harness into the '83? What did you do - splice what you needed in to the factory harness? Are you still using the '83 EEC connector?
To move the pins in the connector you have to pry out the red thing that surrounds the pins. After that's out you can access the plastic "fingers" that hold the pins in. A tiny screwdriver will work, but be careful not to break any of them.
[Image: Im8kTnF.jpg]
[Image: fxPv6f5.jpg]
Go Roush Offline
Yes 88 motor and harness into 83 and spliced in what needs to be from 83 into 88 harness I moved a few wires around according to Pete's pin diagram he sent me. Someone said have to use injectors out of 83 is this what I need to change have power to everything and fuel and spark but no fire
1983 Turbocoupe
Go Roush Offline
I have no boost control solenoid. Will it fire with out it?
1983 Turbocoupe
You need to use the injectors and VAM appropriated to the EEC you are going to use,
1983 EEC = small injectors (green tops, 83,84 85) and small VAM (83-85)
87-88 EECs = large injectors (brown tops 87-88 TCs) and big VAM (from 87-88)
Go Roush Offline
Answered one of my own questions no wire from 83 computer for boost control solenoid so it probably don't care if I don't have one
1983 Turbocoupe
