Compressor Housing
B D Offline
This is a T-3 housing that I modified. If this uploads I will post some more.
B D
87 TC 5-Speed, Remote mount K&N filter system,Steeda Shifter,New Heater Core.
88 Thunderbird Sport 5.0
91 Ranger
[This message has been edited by B D (edited 10-03-2003).]
87 Turbocoupe 5-Speed, Remote mount K&N filter system,Steeda Shifter,New Heater Core,new clutch.
88 Turbocoupe "Mach 1 SE "
88 Thunderbird Sport 5.0 (Retired)
91 Ranger
jabobia Offline
looks purrty...cant wait to see the others?
-james
87 TurboCoupe - 5spd
www.cardomain.com/id/jabobia
jabobia.com
Noname
Guest
Quote:Originally posted by B D:
This is a T-3 housinf that I modified. If this uploads I will post some more.
B D
Looks like a very clean job. I'd suggest machining some sort of taper or lip into the outlet to aid clamping of your I/C hose, though.
Estoril blue 1987 TC 5spd, 141k miles
PRofec B electronic boost controller, kirban fpr, walbro 255 pump, Bailey BOV, Spearco 26x8x3 FMIC, a237 cam, t3/t4 50 trim / stage III .63, 3" exhaust, eec-tuner, 55pph injectors,
Best 1/4 mile: 13.64 (with 2.19 60' time) @ 102.91mph And that was on 93 octane Wink
B D Offline
I had a spare T-3 compressor housing and I wanted to see if I could machine it so that it would work with my stock intercooler. It was an older flanged type. I put it on the mill at work and cut the flange off, and machined it round. It may be a little short, but if I can not use it as is, I can machine an alumimium extension and have it welded on.
B D
91 Ranger
91 Ranger
B D Offline
I can put a lip on the extension if I have to make one. I could not put a lip on the housing at the time I machined it, as that would have required a forming tool,which we did not have. If it is long enough,as is, I can have a bead of weld put on the edge, and blend it into a lip.
B D
91 Ranger
[This message has been edited by B D (edited 10-04-2003).]
91 Ranger
