Yesterday my car was running like it was missing a cylinder and had much less power. I was running 87 and had the boost up around 16 psi didn't hear detonation but that does mean it was happening. I had a recent tune up done when I bought the car a few weeks ago but I went out and bought new wires and plugs anyways, I haven't put them in yet. The car has high miles around 170k and might be on the stock head gasket for all I know. I figured I might as well check the compression before I jump to conclusions. So what should I be looking for with the compression is it 140 psi?
Also is there a way to tell the difference between a blown head gasket and a major engine failure IE-rings, hole in the piston..
88 5 speed TC
Oh yeah if it is a head gasket do you re use the bolts or get new ones? And which head gasket should I be using for a stock head/bore?
88 5 speed TC
140 PSI is fairly typical with the stock cam, but more important is variation between cylinders. All should be within 10% at the maximum.
Bolts: The stock 12 point bolts can be reused. The new 6 point bolts (either Ford or aftermarket)are TTA (torque to angle) and should only be used once.
Post up your compression numbers when you get them and we can go from there as far as what is wrong. After the initial compression test, put a little oil in each cyl and rerun the test. Report back with both sets of numbers.
Thanks for the reply..
Do I need to leave my throttle body open the whole time?
Do I need to leave the spark plugs in on the cylinders im not testing at the time?
How are you dropping in the oil just a regular old funnel?
I know you are supposed to do this on a warm engine but I already pulled the TMIC and the plugs and by the time I get home its gonna be late. Not to mention getting it run long enough to warm up might be a pain. Will doing this on a cold motor really screw things up??
thanks again
88 5 speed TC
Pete D Wrote:See this for testing procedure: http://turbotbird.com/techinfo/Compressi...n_Test.htm
Appreciate it..ill let u guys know what happens tonight!
88 5 speed TC
04-10-2013, 10:30 PM
(This post was last modified: 04-10-2013, 10:37 PM by ianbfromct.)
Does anyone pull the fuel pump fuse before doing this so your not tossing a bunch of fuel in the cylinder or is it not enough to cause a issue?
If so which fuse is it to kill the Fuel Pump?
88 5 speed TC
Stang8u
Dec 2012
Apple valley CA
If you hold the pedal to the floor the pump will not prime
:mad:
So here's what I got 1st without oil and 2nd with.
Piston/psi
1= 50
2=60
3=130
4=150
With oil added
1=60
2=70
3=150
4=190
What do u guys think.. I obviously have a problem
88 5 speed TC
Tbird-fanatic
Oct 2011
Hazel Green, WI
With the compression being low on 1 and 2 and not changing a whole lot with oil Im thinking you have a blown headgasket between them. Looks like its time for you to pull the head. Either that or if you can introduce air into one of the 2 cylinders and have the plug pulled on the other you can see if the air is leaking into the other one.
