hey guys, just needed to know what the compression should be in all 4 cylinders. its an 85 turbocoupe (didnt know if they change by years or not) thanks for any help.
zach
85 Turbocoupe. 5-speed.
Mods- single 2.5 inch exaust with highflow cat and Apex bullit muffler, Saab 9000 front mount IC,Centerforce II clutch kit, Gillis BV set at 19psi,K&N on VAM, Hurst shorthrow shifter.
BEST ET-(1/8)-9.7 @71.9 mph
the way the Ford manuals spec it, the lowest cylinder should be within 75% of the highest cylinder. For example if the highest is 140, the lowest must be at least 101. This is a very wide spread according to other sources.
You really want to see numbers within about 15 psi of each other. 140 to 160 is very good. Below 115 - 110 is getting weak
[This message has been edited by Pete D (edited 10-22-2002).]
DAMN, the highest one i have is 115, the lowest is 70....the other 2 are 85 and 95 maybe..somwhere close to that..what does that mean when my compression is that low...and how much power am i loosing from this??? please help!!!
Dan E
Greensboro, NC
Can be from (among other things):
Valves not seated / seating
Valve Springs weak
Worn Cam Lobes
Cam Timing incorrect (valves opening at the wrong time)
Bad Head Gasket
Piston Rings worn / not sealing (try putting 1-2 teaspoons of oil in the spark plug holes and then repeat the test).
Leaking manifolds to head
God forbid, a cracked head
I'm sure there are other causes...but it's late Yawnnnnnn.
Dan Eaves
[This message has been edited by Dan E (edited 10-23-2002).]
Dan Eaves
ahould i just not worry about it for now? or will it come back and bite me in the ass further down the road...i dont want something to mess up on me...i was thinking about a new damn block...what do you guys think?
Did you have the throttle wide open? (it should be) Was the motor recently run? If the car sat for days before running the test, you will get lower readings.
Did you throw a teaspoon of oil in the cyls and rerun the test?
If the comp is actually that low, you should be able to boost it to 30 psi no problem... hehe [Image: smile.gif]
Those are low figures. Compression should be checked with the engine warm, tube from the VAM to compressor inlet off, and throttle open. Each cylinder should rotate through 5 to 6 Compression strokes (10-12 engine revolutions). After doing all 4 cylinders,
put about a tablespoon of oil and each cylinder and repeat the test on all four cylinders. If the readings increase significately then your low comprssion is due to worn rings. If the readings don't change much then see the list of things Dan posted.
Leaking manifolds don't affect compression
[This message has been edited by Pete D (edited 10-23-2002).]
