longbedGTs
Oct 2004
Amarillo, Texas
Im doing a rear brake job on the TC and have already had to replace the drivers side rear caliper due to the piston not compressing back in. Now Ive gotten to the passengers side and the piston wont move either. Is there some kind of trick with ABS equipped cars(my first brake job on an ABS car) or is this piston just stuck too? Please advise asap.
88 TC 5spd~money pit
88 TC 5spd~78K miles
Ryan H
Oct 2004
Panama City, FL
You use a pair of needle nose pliers in the grooves on the pistons to "screw" them back in while applying pressure. Just watch your fingers if the pliers slip! It helps to take the bleeder loose and just bleed them afterwards. There is a special tool that makes this job simple but its rather expensive for a set of them.
bhpinto79
Mar 2005
St Timothee,quebec,canada
they screw in
White - 88 5 spd w/Gillis & K&N
Joe F
Jul 2002
Hawkins, Texas - USA
Like has already been stated, push and screw and they'll retract. Don't know about the "expensive" tool, but the cheap one I bought didn't fit the grooves without modification.
Good luck!
--> Moving to Suspension, Steering and Brakes forum
