Coming Soon.....brand new .30 over motor!
**PathogeN** Offline
Well...the new motor is just about together and I'm about ready to rip the old one out and get the old bird ready. Anyone got any specific recommendations as to how to make the engine compartment look really nice? I mean i know to paint but what paints work on which parts and stuff? That kinda specifics. Also, I'm thinking of mounting my 7" k&n in the well and am wondering if anyone has done one that big before? I have a hose that puts the first couple inches in the well now and it works better that with it straight off the air meter (its at a 90 deg angle now). Just a few questions cuz I wanna do this once and RIGHT. Thanks in advance.
5-speed, Medium Red.
Homemade Wastegate Bleed Valve for 18 PSI on "new" 12000-mile Turbo. Stock Intercooler,
Ported Upper Intake, K&N, VAF Mod.
4 Piston/gas slotted Brembo Brakes up front, Stock calipers with vented brembo discs in back. Front Calipers cooled via ducting from front fascia.
HPM Rear Lower control arm relocation kit. Eibach Pro-Kit Springs, KYB GR2 Extreme Struts, Tokico shocks and quads,
Full KB Subframe, PST Polygraphite Bushings, Lincoln LSC Sway Bar in front. 225/50ZR16 Dayton Datona's all around.
3" Downpipe, Dual 2.5's, Dynomax Superturbos, Side out Pipes
IASCA 1000W Clarion Pro Audio / Infinity Stereo System
88 Turbo Coupe (White)
88 Psudo Coupe (Silver LX)
Wags88TC Offline
I saw some inner fender aprons for a mustang in a mag a while ago-not sure if they fit the Birds, it laid over the inner fenders to cover all the holes! Looked very clean!! The downside is gotta be trying to find the holes ya need! I used the Moroso 5.0 mustang fresh air filter kit that mounts the filter outside the fender(kinda major modifaction though) Good luck, is your motor gonna be as bitchin as Dan's?
Steve Wagner
Nato member
84 SVO
I recommend you use high temperature paints.
Good luck and send us some pictures of the results
and jack rails.
Will my motor be as bitchin as dans? Why do you have to spoil everything....? LOL.
Well, that all depends on how well everything goes. It'll be fast for damn sure tho. I'll post with all the exact specs a little later once i'm sure they're all right.
