John B
Dec 2015
New Jersey
I have a coilover setup on the car and just saw today while working on it that the hood is coming into contact with the top of strut; the piece that is used to adjust the strut dampening stiffness. I’ve had the coilovers for over a year now and this was never an issue. What could cause this all of a sudden? The strut left a nice dent on the inner hood and now the hood is not sitting flush when closed. Could the hood brackets have shifted? The car has been on jack stands for a few months. Not sure if that would/could cause anything. What do you guys think?
Mikey97D
Jan 2018
CONNECTICUT
Isn't there a rubber isolater on the top of the strut? I would guess the rubber has set from compression.
I have an 88 tbird is their coil overs that are a direct fit?
Mikey97D
Jan 2018
CONNECTICUT
(04-01-2019, 10:47 PM)88turbobird5 Wrote: I have an 88 tbird is their coil overs that are a direct fit?
I am not aware of any now. I think the thing to do would be to use the Mustang ones with the adapters for the shocks on the rear axle.
andrewjs18
Aug 2012
Philadelphia, PA
(04-09-2019, 03:58 PM)Mikey97D Wrote: (04-01-2019, 10:47 PM)88turbobird5 Wrote: I have an 88 tbird is their coil overs that are a direct fit?
yeah, the shock adapters should be used if you're going to run mustang shocks/coilovers...the tbird shocks are 2-3 in longer than the mustang ones so using the shock brackets puts the mustang shock in a mounting position that is very close to the factory length so the shock can travel enough.
we got them on our site: https://tbirdcougarparts.com
