w60
Dec 2011
Birmingham, AL
w60
I removed the wire from the coil to the distributor at both ends. I turned the key to start and there was a really big, really blue spark from the coil post to the first connector toward the back of the car.
Is that normal?
PS...the engine did start after I put the wire from the coil to the distributor back and it sounded pretty good.
https://youtu.be/pGoqo4j6E88
No, not normal.
Did you use dielectric grease in the coil wire boot? Is the top of the coil filthy / greasy?
w60
Dec 2011
Birmingham, AL
w60
There is dielectric grease, but the wire to the distributor wasn't on the coil, just a bare post. Sounds odd...but I didn't pay attention to see if it was greasy, I assume that means a leak of some kind?
It now cranks and runs better than ever. I'm going to let it idle for a while tomorrow so I can check for leaks and adjust the timing.
I also noticed that the PO had run both fans on what looks like 16 ga wire spliced to one of the fan wires on the IRCM. I paid attention to it because I touched it and it was HOT!
Anyway, going to check every ground and connection I can find while I'm performing surgery on this vehicle!
Damp grimy grease can somewhat conduct high voltage. I would ignore what happened and chalk it up to a one time WTF occurance.
