I ran codes today because I get the check engine light coming up when my idle drops below 1000rpm. As soon as I rev it up the light goes out. Occasionally the car just shuts off.
I also have this problem with the check brake lights coming on when I hit the brakes. I have brake and they work well, but the lights come on when I hit the brakes and go off about a second later. When I hit the brakes I also get a humming noise.
Here are the codes and the information I pulled
up for the codes.
*I got no KOEO, but I did get KOER codes
Code 21- ECT sensor out of range(should be 180F to 230F)
Code 75- BOO circuit shorted to power
Code 77- EEC failed to recognize WOT, must be above 3000 RPM, TPS greater than 3.5v and VAF greater than 2.0v change. This is a common operator induced code. Retest
What are the possible ways to fix these problems and what problems do they cause. Thanks
up for the codes.
