I have a 1990 Mustang that has a 1988 Thunderbird Turbo Coupe engine and transmission swapped into. I get codes 81,82,83 and 84 when running the key on engine off test. I do not get an initial Code 11. Is the LA3 supposed to produce a code 11 even when there are other codes stored?
Thank you.
You will not get the system pass code 11 if other codes are stored. Of course, it is possible to get a system pass code 11 for the KOEO test, and fail the KOER test, or vise versa.
Thank you. Exactly what I needed to know.
