DrBob
Jun 2002
Fayetteville, TN
well it appears it is time to replace my clutch. Although it only slips occassionally and then only in 4th gear on a hard acceleration, it still appears this may be the only remedy (unless someone has some suggestions otherwise).
How much should I expect to pay to have my clutch replaced? Maybe not as much $$ as much as the number of hours of labor required (I think only the tranny needs to be dropped and not the engine pulled???).
Thanks
BOB
Bob
88 TC, 5 speed, Medium Canyon Red, charcoal interior, all options except moonroof, added K&N filter.
I waited 15 years to buy a TC - now I know what I missed all those years!!!
mustangtyy
Oct 2001
Findlay, OH
I got a clutch kit from NAPA for only 180$, it included clutch , pressure plate, throw out bearing, and a alinment tool. It just as good as stock though. One thing I did was the throw out bearing that came with the kit sucked so I wet to Ford and got a 30$ good one. As far as time and labor, its not to hard. Engin doesn't need anything done to it besides putting somthing under the oil pan when the tranny bracket is off.
87 TC with 190,000. Gillis valve, K&N on VAM, Home made "Ram" air, Sac Mustang DP to a 3" Dyno Max Super Turbo dumped before rear axle, Ported E6, Paxton AFPR, GN FMIC, RR Cam, T3 at 20 psi, OBX BOV, Spec Stage III Clutch.
Get the flywheel resurfaced or you will be doing it again shortly.
Joe F
Jul 2002
Hawkins, Texas - USA
Also have the rear main seal checked - mine was leaking. It's easy to replace when the flywhell is off anyway.
Artty
Aug 2002
Dillsburg, PA
i replaced mine right after i got the car because i couldn't stop dumping the clutch and burning up ricers at school. it cost me a little over three hundred. i did most of the work myself so the mechanic(friend of the family's)only charged me twenty buck on labor. do yourself a favor though and buy something more high performance. i really don't like the one that i put in from Auto Zone. it used to squeek and it still kinda jiggles under light pressure. spend the extra few dollars and do it right do it once. i'm already planning an upgrade because i don't like the feel when shifting at high rpm's. i never missed a shift before i replaced the clutch but now third is a real problem. i drove my friends TC and he has a Centerforce clutch we put in together and its ten times nicer.
88 TC...she's my second baby.
The 66 K-code Stang hardtop is my first
PsycopathicBird
Aug 2001
Crofton, MD USA
steve just turned me on to star perfeormance, SPEC. i have a stage 2 disc with a stage three plate. im still in the break in period, but goddamn this thing is nice.i cracked the last pressure plate and the disc only lasted 9 months. it was a ram stock replacement. the new one was $267 because i had it 2nd day aired. i highly recommend it. got it through scott.
silver 88 TC with a new stock turbo, holley 155 fuel pump, gauge pod with a/f and boost, K&N cone, and a holley ignition control module, homemade air intake, bosch bypass valve, Single 3" exhaust, Gillis Valve, external Autometer fuel pressure gauge on hood, new falken 502s and stock replacement springs, ngk iridium plugs.
Bring on the track Baby!!
14.95 @ 91.8 so far....
[email protected]
Carcrazyscott
May 2001
Lititz, PA, USA
I'm glad you got it ok. I had them send it out next day air for you to make sure it got there by Thursday. I'm glad you're pleased with it. Let me know how you like it once you really start romping on it.
S&R Racing
http://www.angelfire.com/pa5/srracing/srracing.htm
roushracing6
Oct 2002
Farmington, NH USA
I got a replacment from NAPA it was the cheapest I could find. I would only go performance if you plan on hypeing the car or hammering the clutch. Make sure you turn the flywheel it will make you clutch last much longer no mater what you do. My flywheel had never been turned and the clutch was only slightly worn but all ready slipped wasn't even a year old. Do it right or you will do it often!
88 Tc 211,000 miles slowly rebuilding to stock. Silver with red leather interior loaded with all the toys. My second TC in 1988 bought one as my first new car purchase missed it ever since I sold it in 1991.
88 Tc 211,000 miles Silver with red leather interior loaded with all the toys. My second TC in 1988 bought one as my first new car purchase missed it ever since I sold it in 1991.T-bird died but not forgotten...
