phyxius
Mar 2003
Quebec,Canada
what's a good clutch to use on a tc that will hold up to a min of 250rwhp.what clutch are u using or do u recomend
I'm using a Centerforce II in one car a nd a CF 1 in the other.
Good judgement comes from bad experience, and a lot of that comes from bad judgment.
phyxius
Mar 2003
Quebec,Canada
and which do u prefer out of the two,and just out of curiosity how much were they
Glenn 88TC
Lebanon, PA
I would recommend the Star clutch. You can get 4 different stages to meet you car performance capablities. Check the vendors section for S&R Racing. They have the star clutches listed. Scott is a TC owner and has the stage 3 as do I. I think this is the best clutch I ever had in this car.
Glenn 88TC
current mods: ported & polished big valve head(1.89/1.59), ranger roller, custom upper and ported lower intakes, t3/t4 turbo, powerstroke intercooler mounted full size, 60mm throttle body, R.C. Engineering 42lb. injectors, MSD 6al, MSD Launch Control, MSD 8.5mm wires, K&N filter, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III clutch, Hallman boost controller, Flex-a-lite adj. temp switch for stock fans, Weld Draglites with M/T ET Street 26x11.5/15
87 Merkur Xr4ti - daily driver
NO TC and NO headaches.
