Clutch not engaging well... possible bad throw out berring?
svo_thunderchicken Offline
ok here is the problem. When switching grears, its feels ruff going into gear, and sometimes even grids just a little. If i push in the clutch pettle very swiftly and hard, it shifts fine usually. I had installed a firewall clutch adjuster thinking that the peddle wasnt engaging the clutch fully.... but that wasnt the case. also when i press the clutch in, if you listen out side the car, it sounds like a squeeky door henge... Do you all agree its a throw out berring problem?
84 TC Silver 5 speed - PE EEC, Big Vam, RR cam, 35lb injectors, E6 swap, T3 60 Trim, 87-88 intercooler and hood, BOV, K&N Cone Filter *under constrution*
http://www.cardomain.com/ride/2298891/1
87 TC Black 5 Speed - Stock IHI, BCS Bypassed
http://www.cardomain.com/ride/2390431
The TOB may be squeeky but that may not be the shifting problem. You may not be moving the TO bearing far enough to completely disengage the clutch. Something else to try since it is easy and cheap is to change the tranny fluid first. This often cures a shifting problem
i did that on friday before i made the maden voyage.... didnt help, the adjustable clutch cable did at first, but it started geting bad.. and dont do it all the time....
Maybe the new cable stretched some and needs a follow up adjustment
its been adjusted 3 times in last 2 days..... pettle travel not the problem... help! hjeheh
There may be a spec, in the Service manual, that tells how far the clutch fork should move when the pedal is pushed in. I'm guessing on this but it may exist and you could then evaluate yours
jmthunderbirdturbo Offline
should travel .58 inch(1/2") at the end of the clutch fork. if you have less, you have a problem of travel, if you have more, you have a worn TO bearing, and it could be working its way into the pressure plate fingers. not sure how new all your components are but, this is a place to start.
moller
hth
1987 5.0 sport coupe-msd ignition with blaster coil, 1 7/8 hedmen hedders, K&N intake, new AOD, custom shifter, and PONY wheels.
1987 tc, goldie, mods: mandrel bent downpipe to cat with turn down, gillis valve, 155 lph pump, kirban afpr, 100 psi fuel guage, handmade pvc cold air intake, optima. 15.457 @89.22(special thanks to turbocoupeturbo)(firedoctor)
1988 mazda truck, 431000 mi.
Buisness partner in Aerobird Motorsports.
thanks for the info! i will check that....
also someone told me that my clutch cable could be stretching cause its geting ready to break.. can that cause that problem?
If you got a clutch cable that is getting ready to break this quick there is definetly a problem. It is probably way stretched. Is the cable new?
no.... its the origional cable 84 model
