Clutch issues
mike schrijvers Offline
I Just changed the clutch on my TC as well as the flywheel. Problem is when the car is running I can't get it into gear. When the engine off it is no problem.
1988 TC ,silver,5speed,
1988 TC,silver, 5speed,
1988 TC,black,automatic,
1988 TC ,midnight blue, 5 speed
1988 TC,burgandy, 5speed,
1967 mercury cyclone
1974 charger
1988 TC,red,automatic,521 stroker,1,000 miles
1965 parisienne convertable, red ,automatic,140,000 miles
1970 thunderbird 2door fastback,red ,automatic,76,000 miles
1999 dodge viper RT,black,44,000 miles
2001 plymouth prowler,blue, 8,000 miles
2006 SSR ,yellow, automatic, 26,000 miles
Stang8u Offline
Holy crap you have a lot of cars lol
Maybe it needs to be bled
:mad:
RDOG Offline
Check clutch cable.If not there is a bad synchro in trans. I just did a synchro job on my trans. Synchros cost $200 on a world class unit. I you can do the labor yourself great, but if you cant the cost will be $350-600 with the trans out.
Sorry I should have mentioned it is a 88 TC (hydraulic clutch). The transmision was shifting ok for I replaged the clutch. I had a rear seal leak which I fixed at the same time.
1974 charger
Is there a bleed valve ??
1974 charger
Did the clutch plate go in with the faces in the right directions?
Check the travel if the rod from the hyd slave cyl to clutch fork travel. It should move 0.53 " min.
See this thread for more info; http://natomessageboard.com/ubbthreads.p...#Post93509
BobbyD Offline
Mike, I have sent you a few notes on your email.
This is the first time I've asked a question on this site and I'm amazed at how fast you guys were able to help out. I'll check it out tomorrow and get back to you. Thanks for the help!!
1974 charger
BirdJunkie Offline
Is it a new flywheel or did you have the old one resurfaced?
88 TC 5SPD BLACK MY BABY ORIG.OWNER(garage queen)/06 GTO 6SPD RED WIFES CAR(cop magnet...lol)/2011 TAHOE WHITE (wifes daily driver a.k.a Fifty Cent)/2016 SUPER DUTY RED(my daily driver a.k.a BIG red)/06 HAYABUSA (SEXY BITCH)..STATEFARM LUVS ME. ----N.A.T.O Bad Boy Division President----
I checked the rod on the slave cylinder and it is traveling far enough so the problem is inside the bellhousing. I did have the flywheel resurfaced .
1974 charger
