Cluster replacement
rich Offline
Hi
I just picked up a 140MPH speedo cluster for my Stang LX turbo.
I have heard that the tach will not read correctly but the rest of the gauges should be fine. Is that true? If that is the case I guess the best approach would be to open the cluster and swap speedos right?
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
tps87turbo Offline
Yea...It's not too difficult to swap them out. I did it when I had my 87...Just make sure your hands are clean & dry. You don't want any oily fingerprints on it. Also, be careful not to move the needles when you swap them out. Good Luck
Tony Sceia...Still looking for that car ! ! !
Tony Sceia -
HIS Red 88 TC
