ohioturbocoupe
Jul 2002
Bellville,oh,us
I bought an 88 coupe really cheap but it had a mess of problems with wiring, most of them i have taken care of but i cant get the temp,oil,volts,and fuel to work on the cluster gauge and low fuel light is on when it has a full tank?? i changed the cluster and still it doesn't work anyone have any ideas??
-Levi
Walsted
Fort Worth, TX
Welcome to the board, and congratulations on your purchase.
There is a grey connector near the intake manifold that was disconnected on my TC when I got it. Reconnecting that solved the oil and temp problems.
The IVR (which powers the oil, temp, and fuel gauges, and the low fuel light relay) gets its power from the ignition switch. Are there any other intermittent problems with power that would indicate a (common) switch problem?
My Amp gauge almost never moves.
Hope this helps.
Mike Walsted - NATO member
Pull the plug on the ignition switch & check the terminals.
Dave
'83TC
'85TC
'87TC
ohioturbocoupe
Jul 2002
Bellville,oh,us
what?I dont it, that pull my key ignition switch out and there is a terminal for the gauges....
