turbotbirdguy79
Feb 2004
lockport,ill,united states
I have an 88 turbocoupe that I just put a heater core in a couple of nights ago.(not TOO bad)Any way everything works but my climate control lights flash (little led lights).Everything works though anyone ever heard of this?Im sure I may have forgot to hook up a connector or something.Any help?thanks!
Glenn 88TC
Lebanon, PA
http://www.turbotbird.com/FAQPage/FAQpag...lay_Blinks
mods: SDS Digital Fuel Injection, ported & polished big valve head(1.89/1.59), .500 lift roller cam, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust with Dynomax Ultraflow muffler, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter, Star stage III clutch, Greddy Profec B boost controller, Weld Draglites with M/T ET Street 26x11.5/15
NO TC and NO headaches.
turbotbirdguy79
Feb 2004
thanks a bunch!
Huey866
Jun 2003
Catlettsburg, KY
Nevermind, i found the answer.
Huey
87 Turbo coupe, 5spd, full factory options, custom 3 inch exhaust
[This message has been edited by Huey866 (edited 02-28-2004).]
87 TurboCoupe - silver, 137k, 5-speed, 3.73, 5 lug swap, MM... Evertything, 03 Cobra Brakes, Griggs Subframe connectors, Bo 1.5, Big Valves, massaged 79 turbo head, Essy Cam Gear, Boblog + Elbow, .63 T-3, Stinger Exhaust/FMIC
turbotbirdguy79
Feb 2004
I just forgot to hook up a wire found it thiough!no more flashing!!sweet
