k98311
May 2013
Mount Vernon Washington
Pros, cons? any one have this on theyres?
Not B Anymore
Nokesville, VA, USA
That's how I lowered mine. Well - cutting the springs and removing the isolators. Some like it - some don't. The ride will be stiffer. My advice, if you are going to do it, would be to cut a little at a time until it gets where you want it. Better to have to make multiple cuts than cut too much off.
[Image: Cy6ABhM.jpg]
vinnietbird
Jun 2007
Oklahoma
I simply used SN-95 springs and mine sits like yours.
[Image: 1476092_10203087322370382_522808182_n.jpg]
Not B Anymore
Nokesville, VA, USA
Indeed... but mine was freeeeeee. :rockin:
BJL
Williamstown, New Jersey
B Wrote:Indeed... but mine was freeeeeee. :rockin:
haha mine too! i cut 1/2 coil in front!
running 17in 245/45r17 tires.
[Image: th_2011-10-01_16-55-04_957.jpg]
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
Ramos617
Jan 2013
Fresno, Ca
For the front I cut 5/8 of a coil off the springs
For the rear I installed rear springs from a 96 mustang gt vert
Replaced the struts n shocks with foxbody units and my car handles like it's on rails
1987 T-Bird
Too much stuff to list
Running better than ever
I used 2000-2004 gt springs un cut in rear and 1 coil cut off in front. I think i attached photos front cut and un cut.
http://s531.photobucket.com/user/SKIPKAC...ort=3&o=21
http://s531.photobucket.com/user/SKIPKAC...ort=3&o=17
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
Cut some sn95's on my 88tc with no isolators which can give me a little spring noise when its really cold i've noticed. I cut IIRC 1/2 a coil off.
I also ran semi used Tokicos shocks/struts meant for a SN95 which was a bad idea. Turns out the SN95s struts are slightly longer than fox springs and not to mention they couldn't hold up being on a lowered car. I blew out the Tokicos in a matter of months. Moral of the story buy Fox Koni Yellows once if you lower your bird. When my money tree grows ill be buying a set.
88 5 speed TC
Update: the money tree never grew so I ran some cheapo monro shocks for a Fox body..
I also found my MM struts were not installed correctly so that added to my crappy ride. It was basically bottoming out the strut all the time. It should also be noted I cut SN95s slightly and did not run a isolator. I feel that this was a mistake so I put isolators back in. These gave me enough lift to make it more driveable.
Stock SN on the left...cut SN on the right
Bent from bottoming out on a pothole
Gross
Used plates that I repainted from Chip
How it sits now
88 5 speed TC
CaifanSC
Dec 2003
Laurel, MD
wow, really digging the stance of your car...so that combo is OEM SN95 springs (1/2 coil cut front/rear) and fox-specific struts? did you need isolators or adapters for the springs?
1993 SC 5.0L Auto Red, 1994 SC 5-speed Teal, 1995 SC 5-speed Chameleon Blue
1992 Feature Mustang Convertible 5-speed Vibrant Red, 1991 BMW 850i 6-speed Red, 1994 BMW 850CSi 6-speed Red
