Tbird73
Oct 2012
Tyler,TX
when rotating the crank pulley to check the markings on the cam and crank pulley, it turns until I get about a inch from the cam notch being lined up right. when I try to turn the crank more I cant then I let go and it rotates a little counter clockwise.... what gives??? :dunno:
Greg Corriveau
1987 Black TC stock
God is First ...... I am Second
Plain and Simple!!!
Not B Anymore
Nokesville, VA, USA
It's probably just compression building up. Just keep turning until you get it where it needs to be.... it'll go - just put more pressure on it. You can also turn it a bit and hold it, let the pressure escape, then turn a little more and hold, etc. - repeat until you get to TDC.
Joe F
Jul 2002
Hawkins, Texas - USA
The alternative to putting up with and fighting the pressure build-up is to simply loosen (and remove if desired) the spark plugs.
Viola! End of problem. Ask me how I know... mokin:
Not B Anymore
Nokesville, VA, USA
Why on earth would you want to do it the easy way???
Tbird73
Oct 2012
Tyler,TX
02-10-2013, 06:10 AM
(This post was last modified: 02-10-2013, 06:11 AM by Tbird73.)
Hey Joe, you could always come over and help me get it running!!!! You're only 25 minutes away....
Greg Corriveau
1987 Black TC stock
Plain and Simple!!!
