Checking Temperature gauge and Sensor
GlassRooster Offline
Temp guage hangs at the bottom.
How do I test to see if
I have a wire problem
Dash Guage problem
or a sensor problem.
David
87 TC Faded Burgundy with faded red interior
K&N and cold air ducting- rest is bone stock
02 Mazda Protege 5 Replaced Dead Saturn
99 Cougar- Wife's car new body style now Discontinued.
Remove 1 wire connector from sensor. With key on, connect a 10 ohm resistor from connector to ground (engine block). Gauge should read at max temp line (top white line). Now put a 73 to 75 ohm resistor in. Gauge should read at the lowest white line. A 22 ohm will make the gauge read at 1/2. If these check out, gauge and wiring are OK.
