LilGreenCoupe
Feb 2009
Delaware
Hello all, any idea's on how to get the check turbo light and buzzer to go off? it just started the other day at normal driving conditions, it hasnt been run hard but it came on for sum reason. Its all stock daily driver. Thanks for any help here.
goodstuff84
May 2008
Attleboro Ma
unplugging the overboost solenoid should do the trick.
Justin
88 TC, E-bay 50 trim t3/t4, ported E6, Volvo FMIC, Forge BPV, walbro 255 HP pump, Kirban AFPR, RAM clutch, full 3" stinger single exhaust w/dynomax muffler & dumped at axle, K&N cone on the VAM, *13 base timing, boost @ 20psi. http://s661.photobucket.com/albums/uu337/Goodstuff84/
Tom Senior
Feb 2009
Ridgefield CT
Juston is correct its located on the right fender right behind the strut tower. Pull the wire off it. Your done.
LilGreenCoupe
Feb 2009
Delaware
thanks guys, im gonna give it a try
