cheaper cam alternative to Boport???
ianbfromct Offline
I know everyone praises Bo Ports cams but just wondering if I didnt have $400 bucks to buy a cam from him..any cheaper alternatives out there??
88 5 speed TC
86XR7auto Offline
Moderator
Not really...that's the problem. You can do the ranger roller swap, but only if the stocker is junk. If not...its Bo-port time.
Travis
ianbfromct Offline
I saw these but I havent heard much about guys running comp cams thou..
http://www.compperformancegroupstores.co...ode=70-CAM
88 5 speed TC
boosted chicken Offline
You can keep your eyes open for a good used Motorsport A-237 cam.
One just sold on TF for $150.
I know Bo's cams ain't cheap, but they are worth the $.
ianbfromct Offline
boosted chicken Wrote:You can keep your eyes open for a good used Motorsport A-237 cam.
What do you think about the A-237 vs a Bo Port cam performance-wise??
88 5 speed TC
A237 was not designed to be a turbo cam. Boport cams are. Enough said.
Just spitballin' here, but I would say it might compare to the Boport 1.5 cam.
Cam selection is very dependent on what you want your car to do. I'm very happy with my stg 3 and have actually considered the stg 4 Confusedhocked: , but would prolly need a better intake manifold setup to feed it.
86XR7auto Offline
Moderator
After the heads, the cam is the second most important part of the engine to make power. This is assuming you have ignition and fuel deliver figured out...which isnt easy with a stock turbo EEC4 puter.
Travis
Sean Offline
What's it take to convert the stock 'puter to MAF and make it feed big mods like cam and heads?
1988 Thunderbird Turbo Coupe
160 amp 3G and upgraded charge/power supply cables.
86XR7auto Offline
Moderator
MAF really doesnt work well for the turbo 1983-1988 computers. There is some really good speed density setups for our cars.
Quarterhorse, chips, megasquirt, Pimp..
Travis
Also a wideband O2 is a must.
