CHE or MM control arms
Kuch Offline
SO I'm looking to replace the lower control arms in the back with the adjustables from either CHE or MM, the CHE's are about $100 cheaper, but the MM ones look way more solid. Anyone have any experience with either of these?
andrewjs18 Offline
do you mean CHE?
John B Offline
I have the CHE rear lower and upper control arms. I'm very satisfied with them. I got them in red and did not get the adjustable spring perch. I have coilovers at all four corners so the adjustable spring perch wasn't needed for me.
Kuch Offline
andrewjs18 Wrote:do you mean CHE?
Yes, not sure why I had CHI in my head.
