RDOG
Jun 2001
Ontario. California U.S.A.
I was wondering a few things about my install, that maybe you guys who have the CHE can answer.
1) My car has lots of vibration above 80. Is this due to the stiffer bushings or do I just need a wheel balance and the control arms made it more noticeable?
2)Do I no longer use the rear sway bar? My car had a custom aftermarket unit, but it sits super low and is hell going over speed bumps in my complex and forget going to those mechanical car washes. Pics...
http://i158.photobucket.com/albums/t97/b...xhaust.jpg
(exhaust doesnt look like that anymore, got a new proper offset muffler from stinger)
vinnietbird
Jun 2007
Oklahoma
My CHE's are great, and I use a rear sway bar. I haven't noticed any added vibration at all, although I have no more wheel hop in any gear. If you're worried about the custom sway bar, install a TC bar. I wouldn't run without one. Also, quit going through mechanical car washes.
1988 Thunderbird. No details will be given or spoken of.
lonstar7
Jun 2009
Round Rock, TX
I put mine on last summer, no problems. I don't think your vibration is likely from the control arms.
Lonestar7
1988 Black/Red TC, 5 Speed, 92,400miles (on 4/14/2012). KYB Shocks And Struts, 140MPH Speedo, CHE Rear Control Arms, Otherwise Stock.
2005 Volkswagon Golf GLS 1.9L TDI Turbo Diesel, 5 Speed Manual, InMotion Stage II Chip Tuning
1998 Dodge Ram 2500 4X4, 5.9L Cummings Turbo Diesel, 5 Speed Manual
1988 Firebird Formula 350, 350ci Tuned Port Injection, 700R4 Auto
zbird
Jul 2008
Joshua, Texas
I'd check the U-joints. They tend to go bad and vibrate. If you ain't changed them then I would. With all new bushings you would feel the vibration as you have taken all the play out of the rear.
goldwing
Aug 2009
North Carolina
Whats the difference in the Maximum Motorsports arms and the CHE versions?
I guess the Mustang arms will work. Will they?
T.C:87 5 speed
HOLSET(HE341/HY35W type-D),255 Walbro, No intercooler yet,8lbs boost,Timing @ 9,Low& C.C Plates & SN-95 Bumpsteer Kit, KYB-AGX Struts,Belt driven fan,Custom oil cooler feed,Relocated ECT,Relocated TFI,N/A Hood, showing 178K
vinnietbird
Jun 2007
Oklahoma
I have always been taught that the Mustang arms are shorter.
RDOG
Jun 2001
Yes, I put new ones on front and back(pep boys service dept) . I even changed out the trans mount.
goldwing
Aug 2009
North Carolina
Check out this tbird.
In his discription he says he has Maximum Motorsports arms. M.M dosen't make tbird stuff to my knowledge.
http://forums.vwvortex.com/showthread.ph...65-XXX-KMS
EDIT: I stand corrcted. They do offer Tbird equipment.
T.C:87 5 speed
turbot79
Sep 2007
houstonTX
Yeah but it has to be specially ordered and is not cheap
88 tc, hbc, t3t4, 3"throttle body,3" stinger exhaust, msd, 18psi, Tial 50mm bov, Esslinger adjustable round tooth timing kit, rods header on the way and many more to come
50RACER
Jan 2010
Manassas, VA
Have you checked the pinion angle? It may have changed when you put the new control arms on. Always a good idea to put the adjustable ones on top. If the pinion angle is off, it could be putting a bind on your universal joints.
87 TC Medium Canyon Red
88 TC Black Beauty
