John B
Dec 2015
New Jersey
So I have a pretty bad exhaust leak but I'm still trying to figure out where it's coming from. I seafoamed the car the other day to see and there's definitely a leak but it's on the underside of the turbine / downpipe area. I can't tell if it's the turbo to manifold gasket, turbo to downpipe mating surface or downpipe slip joint.
I plan on taking it all apart this weekend but has anyone had serious issues with the turbo to downpipe mating surfaces or the downpipe slip joint leaking? Just trying to get some ideas before I dig into it. Thanks!
Start spraying all the fasteners with penetrating oil now. I've had problems with each of those at one time or another. Assuming the surfaces are flat then it becomes an issue of alignment and proper torquing that has solved most of the issues I have had.
John B
Dec 2015
New Jersey
Pete D Wrote:Start spraying all the fasteners with penetrating oil now. I've had problems with each of those at one time or another. Assuming the surfaces are flat then it becomes an issue of alignment and proper torquing that has solved most of the issues I have had.
Thanks Pete; what if I take everything apart and the surfaces are warped? I rather not spend the money on getting them machined. I only need this set-up to last until the winter before I go with a gnari manifold and different turbo
I'd look for used parts if something isn't flat. Especially if it involves removing studs in order to machine. Studs can break on old exhaust parts and it costs extra to get those out.
The turbo to manifold gasket is common leak point. My experience is they like to blow on the bottom.
Crap.....I have an exhaust leak and just figured it was manifold to head. I have the gasket, just haven't got to it yet. Guess I should have pulled the intercooler first to find my problem.
Cliff, turbo 2.3 did not come with a manifold to head gasket. They don't hold up. If the issue is manifold flatness, either get it milled or replace it for a lasting fix.
Ok, thanks Pete...Why do they bother selling the part if its a no go?
07-20-2016, 04:58 AM
(This post was last modified: 07-20-2016, 04:58 AM by Pete D.)
The gasket maker's kit includes all gaskets needed for both NA's and turbos.
