08-27-2013, 03:15 AM
(This post was last modified: 08-27-2013, 03:16 AM by kunar.)
starting last friday, the tbird started having battery drainage issues. it would be completely dead in just a few hours. so tonight i started isolating circuits to find the draw, and it's the charging circuit. there's a blue/green fusible link on the solenoid that splits off into three wires, but i havent traced it farther than that. a little background, i just put a used alternator on the car a few days before this happened. it was charging at about 14.5v after the alternator replacement. i unplugged the alternator during the testing i've done, trying to figure out where the draw is and the draw is still there with the alternator unplugged.
i'm working on finding some wiring diagrams to trace these wires down, but does anybody have any ideas? maybe there's something common that could be causing these issues? can anybody think of any problems the used alternator could have caused?
1987 Turbo Coupe
1987 Ranger 4.0, 4x4
1991 Escort GT
Check your PMs
BJL
Williamstown, New Jersey
that is split even more times after that.
it goes to the stop/ hazard lamps.power seat. power locks. keyless entry. auto lights. main light switch. courtesy lamps. power mirrors. illuminated entry.
try pulling fuses 4 ,8 ,12 ,& 16 one at a time.
open the door and latch it and hold the door switch in. so you get better readings.
Brian Larkin
88TC 330,000 miles
Slightly Modified
08-27-2013, 03:38 AM
(This post was last modified: 08-27-2013, 04:00 AM by kunar.)
Pete, email sent
Brain, thanks for the heads up. According to the owners manual, that fuse link is only for the charging circuit. It looks like the yellow one is the one that splits off a million different directions. Either way, i already pulled the fuses one at a time, none of them seem to make any difference. Did it all with the door shut to keep the lights off.
edit: i stand corrected. i see in the diagrams brian sent me that the green fusible link does in fact split off sending power to all the places you had mentioned! i'll double check this stuff tomorrow.
1987 Turbo Coupe
1991 Escort GT
3 emails on the way
Joe F
Jul 2002
Hawkins, Texas - USA
Remove the alternator and have it tested; everything I've seen tells me that a shorted positive diode in the alternator will drain the battery, even with the key off.
My 2¢ worth. Hope it helps.
Probably a bad diode in the alternator. Have it tested as Joe suggested.
The draw is there with the alternator unplugged. I've got a hunch its probably my rear defrost... I'll find out tonight after work now that I've got an awesome set of wiring diagrams and a good explanation of where that circuit goes (thanks Pete and Brian)
1987 Turbo Coupe
1991 Escort GT
after a little bit of a vacation (pawleys island, sc) i finally got back to the tbird today. yes, it's definitely the defrost thats causing issues. the switch looks like it sticks on sometimes, and even comes on by its self. ive got the rear defrost unplugged for the time being. with everything reassembled, its drawing 0.08 amps with the key out, a assume this is knay since i know the computer and radio will have a small constant draw. anybody have more detailed info on the rear defrost circuit? why is it being allowed to stay on with the key off and what fuse or circuit breaker controls it?
1987 Turbo Coupe
1991 Escort GT
I am 99.5% certain the 86 and 88 defroster wiring is the same.
