changing the TFI module
PurpleTC2.3 Offline
Ok we all know a standard 7/32 socket won't fit the TFI module on our TC's. Autozone now has an extended 5.5mm socket the fits into the Ford TFI with no modifications or grinding of the socket. It is a 1/4 " socket and cost about $3 bucks and makes a quick go of it with the small quarter inch wrench.
Gil Ford
87 Turbo Coupe
T3,Ranger Roller..soon and FMIC
Robert Camp Offline
Part number?
Robert Camp
PurpleTC2.3 Offline
Part#557467 75-721 and price is $2.99
Gil Ford
87 Turbo Coupe
Dan S Offline
Craftsman metric nut drivers will also work!
Dan S
1972 Ford F-100 SWB Styleside
2015 Lincoln MKC 2.3 EcoBoost AWD
ipsd Offline
Lisle make a tool just for that. you can do it by hand or it has provisions for a wrench it the bolts are that tight or you can't get you hand down there to turn it. I think it was $5. Also on a side note some of the older ones have Torx bolts from the factory.
Brad Offline
I took one apart once with a Snap On 1/4" Drive 7/32" deepwell socket and it fit just fine. I'm not sure what the part number of it is, because it wasn't my socket, but it worked.
84 Turbocoupe- How I love it so.
tps87turbo Offline
Thats because Snap-On & Mac tools use harder steel & have thinner walls, whereas Craftsman & other cheaper sockets are thicker ---- Which means you need to grind them down. This is no ding against them, as I only have Craftsmen tools.
Tony Sceia -
HIS Red 88 TC
Joe F Offline
The Autozone tool also works on the screws that hold the PIP in place.
Buck Choklit Offline
There's a "Ford Ignition Module Tool" at Advance as well.
No
