Hello, 1988 Turbcoupe, auto. What viscosity is best? Does this require friction modifier?? From dealer only?
I just bought the car, has 74k miles. How often should this oil be changed??
Thanks
DonH
Jun 2002
Central Massachusetts, USA
Book says hypoid gear lube with 4 oz friction modifier, does not specify viscosity but refers to Ford specification and part numbers. Your parts supplier should be able to offer a recommendation. I don't recall a specific mileage interval for changing the lube in 88 but a more recent Ford requirement is that it be changed at 100,000 mile intervals.
1987 TC stock except ATR 2.5"
How much oil?? Can this axle be filled by squeezing the bottle using the tapered nozzle??
turbot-bird
Mar 2005
Winter Garden, Fl. USA
75w-90 and 3.6 pints with friction modifier
MnvlMat
Nov 2007
Manville NJ
I know the newer 8.8s require 75/140 synthetic and friction modifier.
Stock 88 with a 5 speed...
turbot-bird
Mar 2005
my lookup said the 75w-90
from what it looks like in the lookup they switched to 75w-140 in 2002 model year in the mustangs
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
Stinky stuff.....
Where in MI are you from?
Travis
Farmington area
I tend to use Mobil 1 in everything, so I suppose Ill go without FM. 4 pints?? wow, thats alot of lube.
V6TBird87
Apr 2002
Severn, Md, USA
I used Royal Purple in the rear, and it requires no friction modifier. It works well for me.
2018 Mustang GT
1988 Turbo Coupe, 5-speed
aka Tbird232ci
