I finally got to mounting up my gauges in the EQ section of the center panel. I used a piece of sheet plastic like used in model cars and mounted them to the panel itself. I know many have them mounted to the dash and trimmed the panel to fit, but I wanted to be able to easily access the wiring and lights if needed. I soldered up the positive and negative wires so I can run them as one to a power source.
(03-27-2020, 10:05 PM)Kuch Wrote: I finally got to mounting up my gauges in the EQ section of the center panel. I used a piece of sheet plastic like used in model cars and mounted them to the panel itself. I know many have them mounted to the dash and trimmed the panel to fit, but I wanted to be able to easily access the wiring and lights if needed. I soldered up the positive and negative wires so I can run them as one to a power source.
That is a VERY nice setup, Kuch! Great job! I especially like the thumb nuts you have on the terminals, very old school.
Good work! I did the same on my last bird and I loved them! I had used a gauge pod from an Audi Quattro that I got out of a junkyard.
I made a plexiglass panel painted flat black to mount 3 gauges in the EQ slot many years ago. I put an Innovate Motorsports digital A/F gauge, oil temp gauge and battery voltage gauge plus 4 LED indicator lights for various functions in the panel. I also have boost and fuel pressure gauges on the driver side A pillar.
