Catalytic converter
Ricky03 Offline
I'm adding a 3" down pipe and 2 1/2 dual set up my question is what about the cat. Is there much difference in them. Which one will flow the best, less restrictive.
Ricky03 Offline
bump
SteveX82 Offline
Go to http://www.summitracing.com and search for PN CTO-6907.
Estoril blue 1987 TC 5spd, 146k miles, a237, Bailey BOV, spec stg3 clutch, spearco FMIC, t3/t4 50 trim / stage III .63, 3" exhaust, eec-tuner, lm1 wb, 55pph injectors
Best 1/4 mile: 12.89 @ 106mph on 25psi, 1.78 60'
Ricky03 Offline
yea, I saw that one and cto-6007, whats the difference between the two. But most importantly are these more restrictive than others, less,?? Does it matter.
stackz Offline
I just bought my second cto-6007 from summit last night. I've got one on my 88 mustang and just bought one for the svo.
edit: the 6007 has an airtube ability but for some reason is cheaper...I dunno but I just use it cause its cheaper [Image: tongue.gif]
[This message has been edited by stackz (edited 05-06-2005).]
88LX 2.3t-fiddlin with volvo voodoo
86 svo 1D
I am using the 6007. The air tube comes capped off, and I just left it that way. Passed the tough IM240 3 gas emission test we have here a few weeks ago with flying colors.
Ryan H Offline
What is an air tube?
Ryan Harris
1988 TC 5 speed, all options including sunroof, SPEC Stage III. Currently installing: Walbro 255 LPH HP, Kirban AFPR, 3" DP to 2.5" duals, bypassed cat, Magnaflow mufflers Smile
Air tube. a small diameter tube that allows additional air to be fed into the cat, not used on our cars.
[This message has been edited by Pete D (edited 05-07-2005).]
Ryan H Offline
Whats the advantage of having one? Better emissions or something?
Ryan Harris
Ricky03 Offline
Thanks, just ordered one.
