catalytic converter
danadj Offline
what type of catalytic converter does the 88' t-bird turbo coupe have?
88TC Black 5spd conversion, 160k+, with front mounted air filter, aftermarket clutch quadrant, autometer vac/boost gauge, dashcap, Walbro 255lph fuel pump,kirban adj fpr, svo t3, dual
2 1/4 in.
Noname
Guest
Could you be more specific? That's like asking what kind of windshield a car has. Did you intend to ask about the dimensions of the cat instead?
danadj Offline
Is it a bead or a baffle cat?
2 1/4 in.
danadj Offline
What I'm tryin to find out is how to improve the flow of exhaust through the cat. without changing my exhaust system.
2 1/4 in.
GaryS#2 Offline
It is the honeycomb type, I thought GM's only use the beads?
Grocery Getter/Rice Cooker.
BJL Offline
Moderator
beads are on Generic Motors vehicles, and i think som izusu (bascially GM)
baffeled tpere were used on air pump system to recircualte exhaust gas, and then there honey comb style.
Tony Sceia used some "bigger spacing" in the honey comb for the CAT on his 88 TC, i forget the name of it tho, it had al those mathamatic stuff numbers on it!
Brian J Larkin
1988 Turbo Coupe 5spd
dark blue metallic
gillis boost valve, k&n cone,AFPR, 255lph HP pump,3G 130amp alt, 3.73 gears,mild torquie cam, factory DP, 2003 mustang take off SS mufflers and custom BJL 2 1/4 tails.
[This message has been edited by BJL (edited 04-04-2004).]
Brian Larkin
88TC 330,000 miles
Slightly Modified
tps87turbo Offline
I put on an Eastern HI-Flow CAT like Brian said. Its 300 holes per inch instead of the standard 400 holes per inch and made of Polished SS. Kinda Pricy @ 175.00, but its the supposedly the only Tru-flow CAT.
The original cat is on the factory downpipe & angled toward the center. Not sure if the eastern would work for what you are looking to do.
Tony Sceia
Red 88 TC loaded with every option, Walbro 255, 3" SS Downpipe with Magnaflow SS 2.5 Cat Back Mustang Dual system Installed by BJL, 3-core Radiator, Star Stage 2 Clutch, Rebuilt T-5 Tranny, 140 MPH Speedo
Now I need to finish converting to Raven/Gray Leather interior & just do some Body work & she'll be like new.
Tony Sceia -
HIS Red 88 TC
