plstktnkr2
Apr 2007
sharpsburg MD
car is hard to start (takes about half pedal to floor to start, and slowest rpm is 2500 to 3000. new Idle air control, injector cleaner in tank high test gas too
All Ford all the time, 4 stangs 1 lincoln 'vert and 1 turbo 'bird
When did it start and what was the last thing done to the engine before it started?
Look for a vacuum leak and check the TPS and the VAM
http://www.turbotbird.com/techinfo/Idle-...e2005.html
Have you run the codes?
Footintim
Jun 2007
Marcellus, NY
What Jeff K said,
If the idle air was just replaced you may have left a piece of the old gasket behind and is now causing a vacuum leak.
But 1st run the codes...
plstktnkr2
Apr 2007
sharpsburg MD
codes read: TPS is sending no info so it will be done saturday evening. no gasket left behind
not a motor noob
