car revs
georgechard Offline
Car is reving at 15-2000 rpm after warm up. My computer diagnostic tool said knock sensor I changed it out and it passed codes.Still did it so I changed out the idle control selenoid and it is stilll revinggg. HELPPPPPPPPPPPPPPPPPPP.
What codes did you get for the:
1. KOEO
2. Continous cods
3. KOER - the KS code is normal if you don't wrap the manifold to simulate knock. You probably didn't need a new KS, they seldom fail, and it certainly isn't part of the idle problem
Vacuum leak?
TPS closed throttle voltage over 1.0V?
Do not throw parts at the car! diagnose the problem, and just fix what needs fixing.
cloud17 Offline
i had the same problem and my buddy took the part where the sprocket connects to do the idle adjustment(cant remember name)where you unplug, he took it off(just like 2 screws) and opened it up, cleaned it with carb cleaner,and readjusted the idle. what came out was very black and dirty but it runs fine now.
I think Cloud17 is talking about the idle air control (IAC). It is the cylinder like device on the backside of the throttle body. Yes it can cause idle problems. Remove the 2 bolts holding it on and spray it out with carb or brake cleaner until all carbon build up is gone. Replace it and see what happens.
georgechard Offline
I already cleaned the Idle control and it didnt fix it. How do you check voltage at TPS?
georgechard Offline
Thought everyone would enjoy seeing a picture of my 88'turbo coupe Mach 1.
Nice car! I sent you some info on the TPS by e-mail.
georgechard Offline
Thanks a million.
