cbpldc
Jul 2004
columbus, IN, USA
Suppose I had to put a coolant cooled turbo on my car. Could I just run oil through it, or could you use it on the car and just block the coolant passages?
Thanks,
Chris
Blue 87 T/C, basically stock and slow.
Black 85 T/C. The race car.
Yes and many do. Just block off the coolant system
bang4thebuck
Jul 2004
pennsville NJ
ne1 have problems with this type of setup? Longetivity?? Cracking??? Seal life???? Also is it any better if you dont run coolant through it. I would like to run it so the cooland passages are open so that air can circulate around in there to sort of air cool it.
[This message has been edited by bang4thebuck (edited 09-09-2004).]
1987 TC 5 speed. To date: AGP 50 trim T3/T4 .63 stage 2 turbo, Ebay bov, 28psi, 255hp pump, Kirban FPR, Ebay Front mount, Full 3 inch Exhaust, Ported Bob's Log, Megasquirt, 55lb. injectors, boport 1.5 cam, boxed lower control arms, Methanol Kit, Ram HD Clutch, front lowered 1/2 inch and E.T. Streets for the track. Best so far 12.5 at 110.8. still tuning.
