88cat
Jun 2005
Brownsville texas usa
Hey guys can the stock brake stuff on the 88 turbocoupe be able to handle 13' cobra brakes on the front? thanks guys lmk
88 Cougar Bostonian
88 Cougar (351c under construction)
88 TurboCoupe
88 TurboCoupe
87 Turbocoupe: Holset H1C 25 psi, fmic,n2o,stinger header, 38mm ext wg, 3.5 exh, wms sds, innovate wb, c4 3000 stall, 3.55's, p&p head, 70mm tb custom upper intake, ported lower, Alky kit, line lock, all autometer gauges, kirkey seats
88cat
Jun 2005
Does anyone know? thanks guys
88 Cougar Bostonian
88 TurboCoupe
88 TurboCoupe
GaryS#2
May 2001
B.C. Canada
I would think the pump can generate enough pressure.
What about the size of your rims?
Grocery Getter/Rice Cooker.
88cat
Jun 2005
I would be changing to 17' rims just want to know if the stock brake stuff will handle 13 brakes. thanks guys lmk.
88 Cougar Bostonian
88 TurboCoupe
88 TurboCoupe
motormenace
Jun 2001
Timonium, MD
are you going to be running the stock abs? are you going to remove the abs?
86 turbo coupe (14.12 at 15 psi. sleeper) *gone*
...so you have a V8...isn't that cute...
88cat
Jun 2005
I guess the abs is gonna be gone. So will it make enough pressure to handle 13' cobras? thanks guys lmk
88 Cougar Bostonian
88 TurboCoupe
88 TurboCoupe
TheHawk05
Oct 2002
Toronto, Ontario, Canada
It will handle it no problem. I've run the 13" Cobra brakes on my Bird since '97.
