boosted85
Sep 2008
Omaha NE
I posted awhile back about this. I put cobra rims in the bird while it was lowered the po cut the springs some and the front ties would rub on the fenders when i hit bumps well now i want the lowered look back but with good over all handling and ride. I am gonna drag race on the weekend and stomp cars on the street. So basically wat I'm looking for is a decent ride good handling and will hook when i want to race.. Wat r some cheap options i can put together. I hard sn95 springs our struts r good and lower the car some but i want to stay in a reasonable price range...
Complete custom downpipe to tail pipe 3in exhaust, ranger cam, cran double valve springs, stock dsm bov switchin out for a good aftermarket, cone filter, fmi 2.5in piping, walbro 342hp, aeromotive fpr, fuel pressure 45 base, 17in cobra R's, steel braided oil feed line, 96lb injectors, megasquirt 1 v2.2, msd blaster 2 coil 86 t3 48, innovative lc1 wideband,
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
maybe i missed something.....what was the camber question?
1988 TC 2.3/5-Speed, 148K
boosted85
Sep 2008
Omaha NE
O i was wondering wat i could use to camber the front wheels to miss the fender and wat suspension combo to use to lower the car while still giving it strong handling and a decent ride
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
are you serious? you're going to cause way more problems than you solve.
^^^^^ +1
Camber has serious influence on handling and tire wear. It would not be a good thing to use just to improve looks and make things fit inside the fenders. I hearty encourage the development of a plan B.
natmac3
Mar 2002
Aberdeen, MD
Roll the inner fenders, install adjustable caster/camber plates, drop tire size if needed, adjust to preference, and live with it- you will eat tires
None of which will really have any impact on your straight-line performance goals, which would be better off with the stock rims/tires due to less rolling resistance...
1987tc
My 18" wheels and tires don't hit the fenders... if it's low enough to hit 17" cobra R's either your offset is off, or your running to much tire, or it's way too low. That or buy some 40 or 35 series tires to buy yourself some room and gain some gearing for the drag strip. Caster/camber set correctly for the street or in race form dramatically increases the "strong handling and a decent ride" your looking for.
-88 TC Black
-97 Pathfinder
