#11 |
My understanding is that AUX pulley is the same as the stock cam pulley but it is flipped so the marker is actually on the backside; however, even with that being said, I believe the position of the aux pulley does not matter when installing a new timing belt or setting the cam and ignition timing. The important factors are the crank pulley position & distributor rotor position and cam pulley position. 2300gearjammer on youtube has some great videos that show the installation of a timing belt if you want something visual
